UT2004 Server Setup
Moderators: Osiramon, butchski
He he
I'm so glad I'm moving! You guys will work all the bugs out of the Server config and once I'm moved in I'll set up mine and have your configs to use!
Q1:
Why was butchski discussion locked?
I checked the server settings and had;
GameConfig=GameClass="XGame.xVehicleCTFGame",Prefix="VCTF",Acronym="VCTF",GameName="Vehicle CTF",Options=)
The only difference is a case difference I callled the gameName Vehicle CTF instead of Vehiclef. Anyone know if that would cause the problem?
Osiramon
A.K.A. CorpusDecrepid
