Cases/Case Mods
Cases/Case Mods
Show off your lastest Case mod or show us something you found on the Web.
Habitrail, Gerbal heaven inside your PC!
Go ahead get that Gerbal you always wanted! Then let it run around your PC!
http://www.thinkgeek.com/stuff/41/habicase.shtml
Really ausome PC MODS!
Check out this guys web site it seems he professionally makes mod cases!
Guitars, Typewriters, etc..
http://www.envador.com/
Great Site for Small Travel systems
Check out this site for custom built Media/Travel/Gaming PC's and full size as well..
http://www.pugetsystems.com/
Their ultimate Gamer System
Athlon 64 FX55 2.6GHz 64-bit 939 pin CPU
Asus A8N-SLI Deluxe Motherboard
2GB DDR400 CL2.0 (2x1GB) Ram
New! Raptor SATA 10,000RPM 74GB Hard Drive
SLI! 2 x XFX 6800 ULTRA 256MB PCI-E Video Card
SB Live! Audigy 2 ZS Platinum Sound Card
Norton Antivirus 2005 Software
Windows XP Pro SP2 Operating System
80mm Stealth Pro 2 Fan
Koolance PC2-650 Liquid Cooled Tower (1/4 inch tubing)
Floppy Drive
Round Floppy Cable
Arctic Silver V Thermal Compound
Plextor 12X DVD+RW/-RW CDRW SATA
PC Power & Cooling 510W Express
Koolance CPU Waterblock (1/4 inch Tubing)
Koolance Hard Drive Cooler (1/4 inch tubing)
Koolance MB Chipset Cooler (1/4 inch tubing)
SLI! 2 x Koolance Cooler for 6800 GT/Ultra
5581.69
Kinda steep but it comes with a watercooled CPU, Harddrive, and Chipset..
Bet u could overclock to 4 Gig
Floppy Drive
Round Floppy Cable
5581.69
