xbox one
bmeister1
Captain
Captain
xbox one
Post by bmeister1 »
Guys,
I am interested in getting a xbox one. I would like to know if i can hook up the video output from the xbox to my gaming monitor and run the audio into my mixing board. If not, I would like to hook it up into my computer and play on my monitor and have the sound on my audio board. Is this possible?
War_Ghoul
Lieutenant Commander
Re: xbox one
Post by War_Ghoul »
All depends on your monitor and board.
The xbox one has the following for audio/video i/o
HDMI out: HDMI cable connects here and then to your TV.
S/PDIF: Optical audio output (optional; optical cable not included).
HDMI in: HDMI cable connects here and then to your HDMI-compatible cable/satellite receiver
bmeister1
Captain
Captain
Re: xbox one
Post by bmeister1 »
Now I understand what needs to be done with the connections. I would need to go from spidif to an analog converter then into my board. Thanks for the help.
NILL
Re: xbox one
Post by NILL »
If you don't mind going through your controller, you can get a headset adaptor.
I use a combination of this:
http://www.amazon.com/Xbox-One-Stereo-H ... r+xbox+one
and this:
http://www.amazon.com/StarTech-com-head ... r+xbox+one
to use any set of headphones I want. It pumps a stereo mix and the game chat through and you can adjust the mix levels of the two on the adaptor.
bmeister1
Captain
Captain
Re: xbox one
Post by bmeister1 »
Very good suggestions. Something to look into getting in the near future.
