Diggers Den
This is the message board for the Digger's Den (Formally 'Thor's Hammer') DMC Server.
Moderator: THOR
Diggers Den
Ok the Den is up and running, Admin Mod is installed and HPB_Bot
I know almost no one except Murdock and I are interested but, just so its documented.
We have a ton of maps but we lost all the wad files for the custom ones. Working on finding them but its going to be tough, I have a shout out to Butch to see if he has them somewhere.
Bots are configured to use the skins we have which are also a ton, so grab the dl and install it.
Get the maps and the skins at diggsden.led4.net
If you want to remove bots, just kick them, with admin mod.
command admin_help to see commands in console.
Yes its basically classic Quake deathmatch levels but ported to the HL engine. No its not the source engine, I don't think :roll:
Re: Diggers Den
Funny, I have logging on for the DMC server. I looked at the size of the log folder and in basically a day its 1.6 megs in size.
For a split second I was shocked and concerned, then I realized the size of the drive its on and how that was a knee jerk reaction to the past. :lol:
Re: Diggers Den
The wads have all been accounted for and added to the server, correctly :roll: .
So we will be slowly adding to the map rotation, the maps of old.
Fragtown7 is working and I have been in it. :rocker:
