I finally found this post which had all the info I needed.
http://www.tacticalgamer.com/battlefiel ... links.html
BF2142 v1.51 Download Links
It seems we have so many links and versions in the forum there is stil some download confusion, so this is just to clear up the mess of threads and provide you with the official final release links and some basic install help.
1.51 is an incremental patch from 1.50.
You will need to be on patch 1.50 before installing 1.51 patch. If you are not on 1.50 or doing a fresh install, the following link will bring you up to 1.50 from any version. (There is no longer a need to patch to 1.40 first as Northern strike is included in the 1.51 release.)
You can download the FULL 1.50 download from here:
http://largedownloads.ea.com/pub/patche ... e_1.50.exe
If your already on 1.50, then here is the 2GB patch links for 1.51:
v1.51 EA official download links:
http://blogs.battlefield.ea.com/batt...42-update.aspx
v1.51 Bit-torrent download is here:
http://torrents.thepiratebay.org/617...54.TPB.torrent
