$250 or best offer! Like new!
Dell UltraSharp 2407WFP 24in Flat Panel LCD Monitor - Black
Specifications
Display Type LCD display / TFT active matrix
Built-in Devices USB hub, memory card reader
Enclosure Color Black
Display
Diagonal Size 24" - widescreen
Viewable Size 24"
Dot Pitch / Pixel Pitch 0.27 mm
Max Resolution 1920 x 1200 / 60 Hz
Max Sync Rate (V x H) 76 Hz x 81 kHz
Response Time 6 ms
Controls / Adjustments Brightness, contrast, H/V position, sharpness, color balance, color temperature, zoom, phase
Display Positions Adjustments Height, swivel, tilt
Display Screen Coating Anti-glare, hard coating
Signal Input DVI-D, VGA
Features Picture in picture, picture by picture, UltraSharp
Image Color Temperature Adjustable
Image Brightness 450 cd/m2
Image Contrast Ratio 1000:1
Image Max H-View Angle +89 / -89
Image Max V-View Angle +89 / -89
Video Input
Analog Video Signal RGB, S-Video, composite video, component video
Digital Video Standard Digital Visual Interface (DVI)
Expansion / Connectivity
Interfaces 1 x DVI-D - 24 pin digital DVI 4 x Hi-Speed USB downstream - 4 pin USB Type A 1 x VGA - 15 pin HD D-Sub (HD-15) 1 x Hi-Speed USB upstream - 4 pin USB Type B 1 x component video input - RCA x 3 1 x composite video input - RCA 1 x S-video input - 4 pin mini-DIN
Miscellaneous
Flat Panel Mount Interface 100 x 100 mm
Features Security lock slot (cable lock sold separately)
Certified for Windows Vista Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Power
Form Factor Internal
Voltage Required AC 120/230 V ( 50/60 Hz )
Dimensions
Width 22 in
Depth 7.7 in
Height 15.3 in
Weight 18.3 lbs
Dell Ultrasharp 2407 24" LCD Monitor for sale!
Re: Dell Ultrasharp 2407 24" LCD Monitor for sale!
You forgot to add "Free local delivery".
Do you have any pics?
