Dukes of Hazzard HORN for Scorpion (All vehicles have 2 horn
We can use this forum for all news posts about the UT servers.
Moderators: Osiramon, butchski
butchski
Post by butchski »
Butchski here.
All vehicles have 2 horns !!
only 1 (semicolon) is bound, not the second one.
horn2 in the scorpion plays the Dukes of Hazzard "DIXIE
**Quick and dirty (SEE full INFO BELOW..)
Edit your USER.ini, pick a KEY to change (like F) and type
f=playvehiclehorn 1
then jump in any vehicle..
OR, while in game, at console type
set input f playvehiclehorn 1
*** FULL INFO ****
All vehicles have 2 horns. The 2nd one is not set to anything.
the NORMAL horn is set to ; in your USER.ini
with this command (yes, its a gesture command)
Semicolon=Taunt gesture_point
But, to bind the 2nd one , you have to do this
(example bind to "F" key)
Edit USER.ini and type this (no quotes, case not matter)
f=playvehiclehorn 1
then for each vehicle, hit the ; for normal horn
and your NEWKEY for horn2 in the scorpion,
it plays the Dukes of Hazzard "DIXIE"
http://www.ataricommunity.com/forums/sh ... did=376699
thanks,
butchski
harlock
Lieutenant
Lieutenant
Post by harlock »
You mean that the Raptor has a horn? I have to check that out.
butchski
Post by butchski »
YES, ALL VEHICLES have a HORN, in fact, they all have 2 HORNS..
